Put all drawings objects belonging to a specific layer in the foreground.
Is there a simply way to put all drawings objects (blocs, table, polyline, cercle...) belonging to a specific layer in the foreground ?
For example, I would like the objects belonging to the layer "002" to be in the foreground, etc...
Alexis
norman.yuan
You would use DrawOrderTable class to do it, whether you consider that is a "simple way" or not. DrawOrderTable is actually an object wrapper of an ExtensionDictionary of a BlockTableRecord, named as "ACAD_SORTENTS".
Assume you want to do this to entities on layer "002" in ModelSpace, you would open the DrawOrderTable of the ModelSpace BlockTableRecord,  collect all the entity IDs on that layer, then, call DrawOrderTable.Move[Above/Below/ToTop/ToBottom]() method.
Norman Yuan
Drive CAD With Code
Thanks for your answer, I will do that.
