How to Determine What Dll Needs to be Referenced
jmartensBGRRW
jmartensBGRRW
I am working thru an example I found on the AutoCAD DevBlog located here -->Plant 3D Example
After getting the code loaded into Visual Studio, I am missing some dlls that need to be referenced to my project.
I would like to know how do you determine which dll is required? My current approach is running a google search key terms such as “PlantProject” and/or “CurrentProject” shown in the screen shot. Then if I do not locate anything I start to manually add the dlls from AutoCAD Plant3D SDK until all the missing dlls are included in the project.
Is there a better approach to this?
kerry_w_brown
I don't work with Plant3D, so this is a wild assed guess:
Have a look at
https://github.com/ADN-DevTech/Plant3DTraining/blob/master/Labs/LABS_Complete/LAB_01.cs
or perhaps have a look in this template:
https://github.com/ADN-DevTech/Plant3DTraining/blob/master/Tools/VSTemplate/plnt2015template_cs.zip
// Called Kerry or kdub in my other life.
Everything will work just as you expect it to, unless your expectations are incorrect. ~ kdub
Sometimes the question is more important than the answer. ~ kdub
NZST UTC+12 : class keyThumper<T> : Lazy<T>;      another  Swamper
jmartensBGRRW
Thank you for that information.
Ed__Jobe
I would look for the help file outlining the api. I use Electrical and the help file is located here.
C:\Program Files\Autodesk\AutoCAD 2023\Acade\Help\en-US\Help\ACE_API.chm
I would imagine that yours has something similar.
-edit. acad comes with the api. It looks like you have to download an SDK. Look there. The help file should give you an indication of what dll's come with it.
Ed
How to post your code.
