Hi
I have this piece of code that works , values[0] and [1] are like 400,200 500,0 that are read from a text-file. So the script can go in and erase one time or eight times at different locations depending on data in text-file
ed = Application.DocumentManager.MdiActiveDocument.Editor;
ed.Command("ERASE, "CROSS", values[0].Trim(), values[1].Trim(), "");
Now I want to explode also, and thought I could just do
ed.Command("EXPLODE", "CROSS", values[0].Trim(), values[1].Trim(), "");
But it doesn't work at all, I get this output in the command window. But if I type out the commands manually it works fine..
Select object: 4000,2000
None found.
Select object: 0,0
Googling around all example I find is about exploading blocks with certain names or based on user selection, none which will work for me.
What am I doing wrong and what are my options?
Edit1:
Full method that I use to test, with static coordinates
[CommandMethod("valitExplodeTest")]
public static void ExplodeTest() {
var doc = Application.DocumentManager.MdiActiveDocument;
Editor ed = Application.DocumentManager.MdiActiveDocument.Editor;
try {
doc.Editor.ZoomExtents();
ed.Command("EXPLODE", "4000,2000","0,0", "");
} catch (Autodesk.AutoCAD.Runtime.Exception e) {
ed.WriteMessage(e.Message);
}Edit2:
I tried to change the command to some variants, and tried just this
ed.Command("EXPLODE");Which starts the EXPLODE command but I cannot select coordinates as I can if I type in EXPLODE myself, so comparing the arguments that EXPLODE is expecting:
Manual: Expects a point or Window/Last/Crossing/BOX/ALL/Fence/WPolygon/CPolygon/Group/Add/Remove/Multiple/Previous/Undo/AUto/SIngle
From DLL: Expects a point or Last/ALL/Group
Both at least have point..and both have ALL. So I tried all
ed.Command("EXPLODE", "ALL","");The object is not able to be exploded.
So it cannot explode anything...
Do I need to open some transaction or BlockTable or something before running explode? Ideas?
