EXPLODE command by C#
I have a below code that i have wrote based on the copy command ho i performed.
Please find the below code, Its working until the "getSelection" After that this code it not running.
Could anyone have a good suggestion for this would be appreciated. Please correct me where i am getting wrong.
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.Runtime;
using Autodesk.AutoCAD.Geometry;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.EditorInput;
using System;
namespace AutoCAD_Libruary
    public class Class1
        [CommandMethod("XPLD", CommandFlags.UsePickSet)]
        public void Commands()
            Document doc = Application.DocumentManager.MdiActiveDocument;
            Database db = doc.Database;
            Editor ed = doc.Editor;
            using (Transaction transXPLODE = db.TransactionManager.StartTransaction())
                try
                    BlockTable btXPLODE;
                    btXPLODE = transXPLODE.GetObject(db.BlockTableId, OpenMode.ForRead) as BlockTable;
                    BlockTableRecord btrXPLODE;
                    btrXPLODE = transXPLODE.GetObject(btXPLODE[BlockTableRecord.ModelSpace], OpenMode.ForWrite) as BlockTableRecord;
                    object tileMode = Application.GetSystemVariable("TILEMODE");
                    if (System.Convert.ToInt16(tileMode) == 0)
                        Application.SetSystemVariable("TILEMODE", 1);
                    PromptSelectionResult psrXplode = ed.GetSelection(); /*SelectWindow(new Point3d(113000, 13000, 0), new Point3d(100000, -500, 0));*/
                    if (psrXplode.Status == PromptStatus.OK)
                        SelectionSet ssXplode = psrXplode.Value;
                        foreach (SelectedObject sObjXplode in ssXplode)
                            if (sObjXplode != null)
                                DBObjectCollection dbOBJcolXplode = new DBObjectCollection();
                                if (dbOBJcolXplode != null)
                                    foreach (Entity entXplode1 in dbOBJcolXplode)
                                        Entity entXplode = transXPLODE.GetObject(sObjXplode.ObjectId, OpenMode.ForRead) as Entity;
                                        entXplode.Explode(dbOBJcolXplode);
                                        if (entXplode != null)
                                            foreach (DBObject objDB in dbOBJcolXplode)
                                                Entity entXplodeAdd = objDB as Entity;
                                                btrXPLODE.AppendEntity(entXplodeAdd);
                                                transXPLODE.AddNewlyCreatedDBObject(entXplodeAdd, true);
                catch (System.Exception ex)
                    ed.WriteMessage("Error" + ex.Message);
                    transXPLODE.Abort();
                transXPLODE.Commit();
lena.talkhina
Hello @Anonymous !
Great to see you on .NET forum. To get more answers on a question you posted here, don't hesitate to post updates so community members will be notified that you still looking for  a solution.
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям! | Do you find the posts helpful? "LIKE" these posts!
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
Лена Талхина/Lena Talkhina
Менеджер Сообщества - Русский/Community Manager - Russian
fsztuczny
 Hello
I've patched this code a bit, but it's not for production purposes. Treat it as bug fixes that prevent the launch. You still have to learn a lot to get it working properly.
using System;
	public class Class1
		[CommandMethod( "XPLD", CommandFlags.UsePickSet )]
			using( Transaction transXPLODE = db.TransactionManager.StartTransaction() )
				try
					btXPLODE = transXPLODE.GetObject( db.BlockTableId, OpenMode.ForRead ) as BlockTable;
					btrXPLODE = transXPLODE.GetObject( btXPLODE[BlockTableRecord.ModelSpace], OpenMode.ForWrite ) as BlockTableRecord;
					object tileMode = Application.GetSystemVariable( "TILEMODE" );
					if( System.Convert.ToInt16( tileMode ) == 0 )
						Application.SetSystemVariable( "TILEMODE", 1 );
					if( psrXplode.Status == PromptStatus.OK )
						ObjectId[] entColl = psrXplode.Value.GetObjectIds();
						foreach( ObjectId entId in entColl )
							Entity entXplode = transXPLODE.GetObject( entId, OpenMode.ForRead ) as Entity;
							using( DBObjectCollection expObjColl = new DBObjectCollection() )
								entXplode.Explode( expObjColl );
								foreach( DBObject objDB in expObjColl )
									btrXPLODE.AppendEntity( entXplodeAdd );
									transXPLODE.AddNewlyCreatedDBObject( entXplodeAdd, true );
								if( expObjColl.Count > 0 )
									entXplode.UpgradeOpen();
									entXplode.Erase( true );
				catch( System.Exception ex )
					ed.WriteMessage( "Error" + ex.Message );
Thanks for the code correction,
I will check and let you know the status..!!
