Help with JIT error
Help with JIT error
Ed__Jobe
Mentor Mentor
Help with JIT error
Ed__Jobe
Hi, just recently my AutoCAD has started giving runtime errors. The text is below. If you hit Continue on the dialog, it always shows the error one more time. You can still use acad, but you never know when it will throw an error again. Mostly it happens if I'm not using acad and I activate it again.
Application does not support just-in-time (JIT)
debugging. See the end of this message for details.
************** Exception Text **************
System.NullReferenceException: Object reference not set to an instance of an object.
   at Autodesk.AutoCAD.Windows.AcMgPaletteSet.ThemeModified(AcMgPaletteSet* , AdUiThemeElement element)
Ed
How to post your code.
kerry_w_brown
Can we assume that error is from an AutoDesk assembly Ed ??  not one of yours ?
There is a lot of 'unsafe' code in the PaletteSet it seems.
// Called Kerry or kdub in my other life.
Everything will work just as you expect it to, unless your expectations are incorrect. ~ kdub
Sometimes the question is more important than the answer. ~ kdub
NZST UTC+12 : class keyThumper<T> : Lazy<T>;      another  Swamper
daniel_cadext
I didn’t see anything related to CAdUiThemeModifiedReactor::ThemeModified exposed to .NET.
I could be wrong though. If I had to guess, there’s a managed palette that's dangling.
Python for AutoCAD, Python wrappers for ARX https://github.com/CEXT-Dan/PyRx
Ed__Jobe
Yes, it must be something from adesk. I don't do anything with palettes.
Ed
Ed__Jobe
Thanks for checking Daniel. I did a web search yesterday and didn't find anything either. I guess I'll just have to put in a tech support call.
Ed
daniel_cadext
Id try creating a new profile
Ed__Jobe
Thx, I'll keep that in mind.
Ed
