Help with JIT error
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi, just recently my AutoCAD has started giving runtime errors. The text is below. If you hit Continue on the dialog, it always shows the error one more time. You can still use acad, but you never know when it will throw an error again. Mostly it happens if I'm not using acad and I activate it again.
Application does not support just-in-time (JIT)
debugging. See the end of this message for details.
************** Exception Text **************
System.NullReferenceException: Object reference not set to an instance of an object.
at Autodesk.AutoCAD.Windows.AcMgPaletteSet.ThemeModified(AcMgPaletteSet* , AdUiThemeElement element)
Ed
How to post your code.
