Get file type from plotter before plot?
ottosson_mathias
ottosson_mathias
I have two plotters, PublishToWeb JPG.pc3 and PDFXchange 7.pc3. Is it possible to get the file type of the plot before plotting, preferably from the PlotConfigInfo or something similar if possible?
I need to be able to set scale unit to pixels if the plotter is outputting jpg and mm/inches if it's a pdf. I don't know beforehand what plotters are available.
Thanks!
SENL1362
You can get a list of PlotDevices with:
PlotConfigManager.RefreshList(RefreshCode.RefreshDevicesList);
string plotDevNames=null;
using (PlotConfigInfoCollection plotDevices= PlotConfigManager.Devices)
  if (plotDevices != null && plotDevices.Count > 0)
   plotDevNames = plotDevices.Cast<PlotConfigInfo>()
   .Select(n => n.DeviceName).ToList();
And based on the (pc3)Name of the device you can decide to set the Units, Scale etc.
var lm = LayoutManager.Current;
var psv = PlotSettingsValidator.Current;
using (var tr = db.TransactionManager.StartTransaction())
  var layoutName = lm.CurrentLayout;
  var layoutId = lm.GetLayoutId(layoutName);
  var layout = (Layout)tr.GetObject(layoutId, OpenMode.ForRead);
  using (var ps = new PlotSettings(layout.ModelType))
    ps.CopyFrom(layout);
    //Set or Change the PlotDevice
    //psv.SetPlotConfigurationName(ps, pc3Name, null);
    //psv.RefreshLists(ps);
    //or Get the PlotDevice and set Units accordingly
    var pc3Name=ps.PlotConfigurationName;
    var psUnits=(pc3Name.Contains("PDF",StringComparison.OrdinalIgnoreCase) ? PlotPaperUnit.Millimeters : PlotPaperUnit.Pixels;
    psv.SetPlotPaperUnits(ps, psUnits);
    layout.CopyFrom(ps);
  tr.Commit();
PS: you might need this String Extension for the Case Insensitive Compare
public static class StringExtension
  public static bool Contains(this string source, string toCheck, StringComparison compType)
    return source != null && toCheck != null && source.IndexOf(toCheck, compType) >= 0;
ottosson_mathias
Thanks but this is not a robust solution. The plotter name does not always contain the type of plotter. Bluebeam does not have pdf in its plotter name for example.
SENL1362
You are absolutely Right!
But you asked for a solution for the plotters mentioned above.
SENL1362
When you start the AutoCAD Plot command you'll see PDF options for PDF type drivers.
I don't think we have access to these details from the Net API's.
Have a look at my entry to the post: Add plot custom paper size (07-30-2014).
It shows some C# code to read the contents of PC3 and PMP files. For a PDF type of pc3 you find what you are looking for, as show below.
