RibbonButton like the Insert dropdown of buttons
I am trying to make a dropdown of buttons like the Insert button. Does anyone know type of button that is?
gleeuwdrent
You can use this as extension method (and your own method to load your icon):
public static RibbonMenuButton AddMenuButton(this RibbonRowPanel rowPanel, string buttonId, string buttonText, string iconName)
	RibbonMenuButton menuButton = new RibbonMenuButton();
	menuButton.Text = buttonText;
	menuButton.Orientation = System.Windows.Controls.Orientation.Horizontal;
	menuButton.Size = RibbonItemSize.Standard;
	menuButton.ShowText = true;
	menuButton.LargeImage = LoadImage(iconName, 32, 32);
	menuButton.Image = LoadImage(iconName, 16, 16);
	menuButton.ShowImage = true;
	menuButton.ListButtonStyle = Autodesk.Private.Windows.RibbonListButtonStyle.MenuButton;
	menuButton.Id = buttonId;
	rowPanel.Items.Add(menuButton);
	rowPanel.Items.Add(new RibbonRowBreak());
	return menuButton;
How do I add items to the menu?
gleeuwdrent
I use this extension:
public static void AddButtonToDropDown(this RibbonMenuButton menuButton, string buttonId, string buttonText, string description, string iconName, string command)
	RibbonMenuItem button = new RibbonMenuItem();
	button.Text = buttonText;
	button.ShowText = true;
	button.ShowImage = true;
	button.LargeImage = LoadImage(iconName,, 32, 32);
	button.Image = LoadImage(iconName, 16, 16);
	button.Id = buttonId;
	button.CommandParameter = command;
	button.Description = description;
	button.CommandHandler = new AdskCommandHandler();
	menuButton.Items.Add(button);
With this CommandHandler:
public class AdskCommandHandler : System.Windows.Input.ICommand
	public bool CanExecute(object parameter)
		return true;
	public event EventHandler CanExecuteChanged;
	public void Execute(object parameter)
		var ribbonItem = parameter as RibbonCommandItem;
		if (ribbonItem != null)
			Autodesk.AutoCAD.ApplicationServices.Document doc = AcAp.DocumentManager.MdiActiveDocument;
			//Make sure the command text either ends with ";", or a " "
			string cmdText = ((string)ribbonItem.CommandParameter).Trim();
			if (!cmdText.EndsWith(";")) cmdText = cmdText + " ";
			doc.SendStringToExecute(cmdText, true, false, true);
