Developing plugin for AutoCAD and BricsCAD
I am having trouble. When trying to use a #if in C# to determine which using namespaces are used it doesn't seem to recognize any of them.
Is there a better solution to creating a plugin for both programs?
_gile
First, you should have a look to the Bricscad documentation.
Then, in the same Visual Studio solution, you create 2 projects with a different conditional compilation symbol (e.g. BRX_APP and ARX_APP).
Write the code which have to be shared between the two projects in a class of one the projects and "add as link" this class to the other one.
Gilles Chanteau
GileCAD
GitHub
