Cad Add-in Manager
Cad Add-in Manager
Ahmmed-saber
Cad Add-in Manager
Ahmmed-saber
i downloaded CadAddInManager to check the dlll file , without close & re-open Autocad or Civil3D each time from this link
but this message show when running the command AddInManager Manual from civil 3D 2025
any one help for this problem
Ed__Jobe
I don't see the missing library in his repository. If you can find the dll on your hard drive, you can click on the LOAD button. Otherwise, I suggest you contact the author.
Ed
How to post your code.
kerry_w_brown
This may help
https://github.com/search?q=repo%3Achuongmep%2FCadAddinManager%20Mono&type=code
https://www.mono-project.com/docs/tools+libraries/libraries/Mono.Cecil/
// Called Kerry or kdub in my other life.
Everything will work just as you expect it to, unless your expectations are incorrect. ~ kdub
Sometimes the question is more important than the answer. ~ kdub
NZST UTC+12 : class keyThumper<T> : Lazy<T>;      another  Swamper
Chuong.Ho
Hi @Ahmmed-saber , this is bug known and fixed.
Regards
Chuong Ho
S_S_SS
Hello sir,
can i get the final of it with the fixation of this bug ??
thanks in advance
Chuong.Ho
Please using this link to download latest version  :https://github.com/chuongmep/CadAddinManager/releases/latest
Chuong Ho
S_S_SS
okay thanks my brother
