Hi everyone,
I want to export a portion of the Model Space as an image file (PNG/JPEG). Specifically, I’d like to define two corner points (like a window) and then generate an image that covers only that area of the drawing.
I’ve already managed to do this using a BMP export, but the resolution is very low and the output quality isn’t acceptable. What I need is a higher-quality image (PNG/JPEG, with better DPI or scaling).
- Is there a way to capture a “window area” in Model Space and save it as a high-resolution image?
- Should I use the plotting API for this, or is there another recommended method?
Any sample code or guidance would be greatly appreciated.
Thanks!
