LwPolyline - Edit ConstantWidth
Hi !
i want to read the ConstantWidth of a lwpolyline and add a additional width.
the problem is, that the program frozze, when "polyline.ConstantWidth = newWidth"!!
any idea?
the code:
Public Function LayerAddLineWidth(ByVal LayerFilter As String,
ByVal AddLineWidth As Double,
Optional Log As EBL.Logger.Log = Nothing,
Optional ByRef Execute As Boolean = True) As Boolean
AcReInit()
Dim Obj2Modify As ObjectIdCollection
Obj2Modify = GetEntitiesOnLayer(LayerFilter, Elementtyp:="LWPOLYLINE")
Dim InfoMsg As String = ""
If Obj2Modify.Count = 0 Then
If IsNothing(Log) Then
_Editor.WriteMessage(InfoMsg & vbCrLf)
Else
Log.Write(InfoMsg)
Return True
InfoMsg = "Anzahl gefilterter Objekte: " & Obj2Modify.Count.ToString & vbCrLf
Else
Log.Write(InfoMsg)
Try
Using _AcDocument.LockDocument
Using tr As Transaction = _Database.TransactionManager.StartTransaction()
If Execute = True Then
For i As Integer = 0 To Obj2Modify.Count - 1
Try
'Dim text = tr.GetObject(Obj2Modify(i), Autodesk.AutoCAD.DatabaseServices.OpenMode.ForWrite)
Dim ent As Entity = CType(tr.GetObject(Obj2Modify(i), Autodesk.AutoCAD.DatabaseServices.OpenMode.ForRead), Entity)
Dim polyline As Autodesk.AutoCAD.DatabaseServices.Polyline = CType(ent, Autodesk.AutoCAD.DatabaseServices.Polyline)
' Linienbreite auslesen
Dim currentWidth As Double = polyline.ConstantWidth
' Linienbreite bestimmen
Dim newWidth As Double = currentWidth + AddLineWidth
Catch ex As Exception
Dim ErrMsg As String = "unerwarteter Fehler in EBL.Service > Acad > LayerAddLineWidth - Loop" & vbCrLf &
"AddLineWidth:= " & AddLineWidth.ToString("0.000") & vbCrLf &
LogStatus4TryCatch(Log) &
"Execute:= " & Execute.ToString & vbCrLf &
ex.ToString()
If Not IsNothing(Log) Then
Log.Write(ErrMsg)
Return False
End Try
Next i
tr.Commit()
Else
_Editor.WriteMessage("** Befehlssimulation **" & vbCrLf)
End Using 'Transaction
End Using ' LockDocument
Dim ErrMsg As String = "unerwarteter Fehler in EBL.Service > Acad > LayerAddLineWidth" & vbCrLf &
ex.ToString()
Log.Write(ErrMsg)
Return False
End Try
Return True
End Function
Public Function GetEntitiesOnLayer(LayerName As String,
Optional Elementtyp As String = "",
Optional TextHeight As Double = -1,
Optional ByRef Log As EBL.Logger.Log = Nothing) As ObjectIdCollection
' https://gis-wiki.local.ebhl.de/eblwiki/index.php?title=Acad_(Klasse_von_EBL.Service)#GetEntitiesOnLayer
' Quelle: http://through-the-interface.typepad.com/through_the_interface/2008/05/finding-all-the.html
AcReInit()
' Build a filter list so that only entities
' on the specified layer are selected
Try
Dim tvs = New List(Of TypedValue) From {
New TypedValue(CInt(DxfCode.LayerName), LayerName)
' Dim tvs As TypedValue() = New TypedValue(0) {New TypedValue(CInt(DxfCode.LayerName), layerName)}
If Elementtyp.Length > 0 Then tvs.Add(New TypedValue(CInt(DxfCode.Start), Elementtyp))
If TextHeight > 0 Then tvs.Add(New TypedValue(CInt(DxfCode.TxtSize), TextHeight))
_Editor.WriteMessage("Filterdefinition:= ")
For i As Integer = 0 To tvs.Count - 1
_Editor.WriteMessage("(" & tvs(i).TypeCode.ToString & ", " & tvs(i).Value.ToString & ")")
Next 'i
_Editor.WriteMessage(vbCrLf)
Dim sf As New SelectionFilter(tvs.ToArray)
Dim psr As PromptSelectionResult = _Editor.SelectAll(sf)
If psr.Status = PromptStatus.OK Then
Return New ObjectIdCollection(psr.Value.GetObjectIds())
Else
Return Nothing
Dim ErrMsg As String = "unerwarteter Fehler in EBL.Service > cls_Acad > GetEntitiesOnLayer" & vbCrLf & ex.ToString
Log.WriteAsError(ErrMsg)
Else
_Editor.WriteMessage(ErrMsg & vbCrLf)
End Try
Return Nothing
End Function
regards jan
