I am opening .dwg files created in Autocad plant 3d 2022 in Navisworks 2023 manage, but some objects appear as wireframe, I am missing the object enabler but I can not find one, the 2022 version which I found here https://knowledge.autodesk.com/support/autocad/downloads/caas/downloads/content/autodesk-autocad-pla...doesn't help.
Solved by DarrenP. Go to Solution.
i think they are only on your Autodesk Account under product updates
DarrenP
The 2023 object enablers are in your Autodesk account
DarrenP
I do not see it as available in the Autodesk Desktop App nor my https://manage.autodesk.com/products/updates page
I do see a couple Civil 3D object enablers and one Advance Steel object enabler.
I am using the PD&M package, switched from the AEC package in September.
It should be in the same place you see those other object enablers
DarrenP
Screencaps of what I see as available plugins are attached.
I also see C:\Autodesk\AutoCAD_Plant_3D_2022_Object_Enabler_English_Win_64bit_dlm on my disk.
Thanks.
Your looking under Plant 3d
Did you look under Autocad?
Plant 3d won’t show an object enabler for itself
DarrenP
Well, thanks again. And surprise!
Which brings me back to the original question: if I do already have the proper object enabler installed, why am I seeing wireframe fittings in Navisworks unless I export to AutoCAD from Plant 3D first and then open the file with Navisworks.?
I've the same issue. Navis 2023, Plant 3D Object Enablers installed, everything but pipe showing as wireframe;
https://forums.autodesk.com/t5/navisworks-forum/everything-shows-as-wireframe/td-p/11578857
You can also try these links;
Hopefully something in them will work for you. None of these worked for me.
When you have your file loaded in Navisworks, you can also try checking the scene statistics. Scroll through the entire list and see if there are any Errors called out. That may give you a bit of help.
