Navisworks Forum
Welcome to Autodesk’s Navisworks Forums. Share your knowledge, ask questions, and explore popular Navisworks topics.
Can not find object enabler for Navisworks 2023
11 REPLIES 11
Message 1 of 12
shadow931
2773 Views, 11 Replies
I am opening .dwg files created in Autocad plant 3d 2022 in Navisworks 2023 manage, but some objects appear as wireframe, I am missing the object enabler but I can not find one, the 2022 version which I found here https://knowledge.autodesk.com/support/autocad/downloads/caas/downloads/content/autodesk-autocad-pla...doesn't help.
11 REPLIES 11
Message 2 of 12
DarrenP
in reply to: shadow931
i think they are only on your Autodesk Account under product updates
DarrenP
Message 3 of 12
shadow931
You are correct, I should have checked there sooner.
Message 4 of 12
pbowers26JWP
As far as I can tell, there is no Object Enabler for Plant 3D 2023.
Message 5 of 12
DarrenP
in reply to: pbowers26JWP
The 2023 object enablers are in your Autodesk account
DarrenP
Message 6 of 12
pbowers26JWP
in reply to: DarrenP
I do not see it as available in the Autodesk Desktop App nor my  https://manage.autodesk.com/products/updates page
I do see a couple Civil 3D object enablers and one Advance Steel object enabler.
I am using the PD&M package, switched from the AEC package in September.
Message 7 of 12
DarrenP
It should be in the same place you see those other object enablers
DarrenP
Message 8 of 12
pbowers26JWP
Screencaps of what I see as available plugins are attached.
I also see   C:\Autodesk\AutoCAD_Plant_3D_2022_Object_Enabler_English_Win_64bit_dlm  on my disk.
Thanks.
Message 9 of 12
DarrenP
Your looking under Plant 3d
Did you look under Autocad?
Plant 3d won’t show an object enabler for itself
DarrenP
Message 10 of 12
pbowers26JWP
Well, thanks again. And surprise!
Which brings me back to the original question: if I do already have the proper object enabler installed, why am I seeing wireframe fittings in Navisworks unless I export to AutoCAD from Plant 3D first and then open the file with Navisworks.?
Message 11 of 12
tstorzuk
@pbowers26JWP
I've the same issue. Navis 2023, Plant 3D Object Enablers installed, everything but pipe showing as wireframe;
https://forums.autodesk.com/t5/navisworks-forum/everything-shows-as-wireframe/td-p/11578857
You can also try these links;
https://knowledge.autodesk.com/support/navisworks-products/troubleshooting/caas/sfdcarticles/sfdcart...
Hopefully something in them will work for you. None of these worked for me.
When you have your file loaded in Navisworks, you can also try checking the scene statistics. Scroll through the entire list and see if there are any Errors called out. That may give you a bit of help.
Message 12 of 12
Thank you so much ,Guys.
Rail Community
