Appearance Profiler Display Order
tcookYCXTL
tcookYCXTL
With properties and set profiles identified, what is the order appearance profiler decides how to apply colors?  Top down in the list?  Can you have properties and sets identified?  Does one override the other?
My goal is to have the insulation on my insulated piping show in contrast to the pipe it is applied to.
Thanks.
PatrickDavis20
As far as I know, the order in which appearance profiler items are applied is not documented. I have found that the order seems to come from the list and it is top-down. Items in the list can override previous items.
Patrick Davis
Twitter
LinkedIn
Blog
hmunsell
If you make a search set(s) that can identify the insulation vs the pipe, you should be able to use the search set to assign a color to it.
Howard Munsell
Bob_Boehme
I created a selection set collecting everything on "AutoCAD Layer contains _Insulation"
alvaro.ruizWRCR3
Community Visitor
Community Visitor
Hi there
Do you know of a way to reorder appearance profiler display rules?
Alvaro
