I'm following several tutorials describing how to load CFD results into Nastran. The procedure, as I understood it, is to use the From Output option in the Loads dialog, then select your .cfdst file, and choose the design/scenario and the type of load from the two drop down menus. The issue I'm facing is that Nastran will not read .cfdst file results, as in when I locate my .cfdst file, the two drop down menus are empty.
At first I thought there was an issue with my model but to troubleshoot the issue I prepared a simplest model to eliminate any geometry etc. pitfalls, ran a very coarse mesh simulation in CFD, and tried to load the results into Nastran. Still no luck. I have attached the CFD and Inventor/Nastran models here. Please can someone take a look and point me to what I'm doing wrong?
Solved by John_Holtz. Go to Solution.
Hi @milos28HR3
What version of Inventor Nastran are you using?
John
Hi John,
Thank you for clarifying that for me. Yes, downgrading to 2021 versions fixed it for me.
For anyone else who might be going through the same issue, I was not able to load CFD 2023 results into Inventor 2022, nor 2021, and had to downgrade both programs to 2021 version (as there is no CFD 2022).
