Surface contact type between solid and shell for doubling plate
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hello all,
I was working with some doubling plates today with some linear static analysis. I tried out 3 different contact types for a doubling plate (solid) on top of a shell model. Which resulted in 3 completely different results. I am wondering why.
Below I schematically drew the setups I tested.
A:
I have a shell surface 4mm thick plate. Offset is set in a way that the outside surface is modeled (solid blue line) and the 4mm plate is inward (blue dotted line)
On top my doubling plate solid with the structure connected to it. The stresses in the corner on top of the doubling plate are measured (blue arrow).
I offset bonded shell surface to the underside surfaces of the doubling plate.
B:
Situation B is the same as A, only I changed the contact type to bonded.
C:
In C I changed the shell and solid models.
I made the doubling plate 4mm thinker and made a hole in the surface model.
So now the edge of the surface model is touching the side on my solid model.
I made a surface - edge offset bonded contact between the two.
*10mm max act dist yields the exact same results
Geometry wise these 3 situations should behave similarly right?
However when I measure the stress in the corner with the blue arrow I get different results.
If A is 100MPa, then B is 250MPa and C is 300MPa.
Why does this happen? Which would be most accurate?
Thanks.
