Announcements
Probing The Exact Same Area After Multiple Runs
Ruwan.B
Ruwan.B
Hi all!
I am wondering about the probe function within Inventor Nastran 2023. How can I probe the exact same area after multiple refinements?
I am running an linear static analysis with a course mesh, and systematically reducing the mesh size. When I place a probe with the first iteration and then refine the mesh and run the analysis again, it seems that the probe does not update with the results.
Maybe I'm doing something wrong.
Any assistance would be greatly appreciated.
John_Holtz
Autodesk Support
Autodesk Support
Hi @Ruwan.B
I just did a test with Inventor Nastran 2023 and agree with you. In particular,
  • When you use the Ribbon "Results > Probes" and click on the model to attach the probe, it shows the result for Element X.
  • If you change the mesh and re-run the analysis, the probe still shows the value from Element X even though element X is now in a different location. (Note that the value shown in the probe does update to show the new value for element X, but that is not what you want.)
In other words, the value shown by the probe is based on the element number. (The position on the screen is based on the original X, Y, Z coordinates when you click which doesn't change even when the displacement is turned off or the scale is changed.)
If you only have a few positions to probe, the alternative would be to split the face of the model so that a node is created at the specific location. (Or you can add points to a sketch and create Mesh Control points at the locations; that will also generate nodes at specific locations.) Then use the Model Tree right-click "Nodes > Query Display". Since the coordinates of the nodes remain the same regardless of the mesh size, you can get the result from a fixed position.
John
John Holtz, P.E.
Global Product Support
Autodesk, Inc.
If not provided already, be sure to indicate the version of Inventor Nastran you are using!
"The knowledge you seek is at knowledge.autodesk.com" - Confucius 😉
Ruwan.B
Hi @John_Holtz
Thank you for your advice. I will definitely give that a go.
Regards
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
