Hi all!
I am wondering about the probe function within Inventor Nastran 2023. How can I probe the exact same area after multiple refinements?
I am running an linear static analysis with a course mesh, and systematically reducing the mesh size. When I place a probe with the first iteration and then refine the mesh and run the analysis again, it seems that the probe does not update with the results.
Maybe I'm doing something wrong.
Any assistance would be greatly appreciated.
Solved by John_Holtz. Go to Solution.
Hi @Ruwan.B
I just did a test with Inventor Nastran 2023 and agree with you. In particular,
In other words, the value shown by the probe is based on the element number. (The position on the screen is based on the original X, Y, Z coordinates when you click which doesn't change even when the displacement is turned off or the scale is changed.)
If you only have a few positions to probe, the alternative would be to split the face of the model so that a node is created at the specific location. (Or you can add points to a sketch and create Mesh Control points at the locations; that will also generate nodes at specific locations.) Then use the Model Tree right-click "Nodes > Query Display". Since the coordinates of the nodes remain the same regardless of the mesh size, you can get the result from a fixed position.
John
