HI , IAM TRYING TO APPLY MOMENT LOAD ON BELOW ATTACHED PART. BUT UNABLE TO RUN THE ANALYSIS. ALWAYS GETTING SINGULARITY ERROR.
Solved by John_Holtz. Go to Solution.
Hi @poornam07
Your file has no input for the analysis. Can you attach the file that has the Nastran setup?
In general, a singularity indicates the analysis is not statically stable, either because
John
