Mudbox Forum
Welcome to Autodesk’s Mudbox Forums. Share your knowledge, ask questions, and explore popular Mudbox topics.
Sculpt using Displacement Map - ONLY HALF ?
9 REPLIES 9
Message 1 of 10
972 Views, 9 Replies
When I sculpt  with displacement map, half of the mesh has the displacement map applied the other half, nothing.  I've included a picture of the result as well as part of the displacement/UV texture.
Sculpt with Displacement Result
Displacement / UV Map (Portion)
9 REPLIES 9
Message 2 of 10
3dMastermind
Hello.
This works with your existing UV set.
Please be sure that the UVs are OK.
Look in the "UV view" tab.
Also. try painting in that area, it may reveal bad/overlapping UVs.
Manny Papamanos
StingRay | MotionBuilder | Maya | Mudbox
Games QA Specialist
Message 3 of 10
in reply to: 3dMastermind
Painting on the Mesh is good, it can't be the UV's.
Message 4 of 10
3dMastermind
Are you using an image with a Vector Displacement Map and setting that as a stamp to sculpt with?
I tested the "human body" character by setting a VDM stamp (the square) and drawing all around the arm and it seems to work well.
What are you doing exactly?
Manny Papamanos
Games QA Specialist
Message 5 of 10
I'm using a B&W Image followed by Sculpt using Displacement map. The result is what is shown in the first image.
Message 6 of 10
Any update on this issue ?
Message 7 of 10
3dMastermind
Hi.
Its hard to tell what can be going on.
It could be due to a pose deformation.
We would need the actual scene to validate.
Can you send it via the logged request 08964753.
I will send you a message.
Please reply and attach the scene.
If the scene is over 12Mb , let me know and I will create an FTP container and send you the link.
Thanks.
Manny Papamanos
Games QA Specialist
Message 8 of 10
You may have informed me of something I didn't know. The pose deformation, may not work, which doesn't make sense to me why it wouldn't. I just applied a sculpt with displacement on a bent object and it worked fine.
I'll have to send you the scene with just the object, do you want the displacement map as well ?
Message 9 of 10
3dMastermind
Hi Christopher,
I analysed the scene you sent us.
At first, I thought it may be a normals issue but they are
fine.
Look at the attached pic.
Its a case of UVs being too packed and not
covering the 0,0 to 1,1 space.
I also tested with a new cylindrical element made and UV'ed
in Softimage.
Once imported in Mudbox, all is good with the displacement.
Let us know if this answers your question.
Best regards,
Manny Papamanos
Games QA Specialist
Message 10 of 10
3DMastermind had helped me realize my head went into hibernation.
