Mudbox Forum
Welcome to Autodesk’s Mudbox Forums. Share your knowledge, ask questions, and explore popular Mudbox topics.
Mudbox moves UVs at texture export
4 REPLIES 4
1798 Views, 4 Replies
I have created a UV Atlas in Maya for four models. No UVs overlap any other:
I export these 4 models into the same Mudbox scene and with the UV map.
I set a separate material for each model to sculpt high-poly and texture.
I'd like to keep the atlas format of the textures, so I intended merging the models layers in photoshop into a single texture. (I can't find a way to extract a channel of all models in one).
However I'm finding maya or mudbox move the UVs so the shells end up one on top of the other.
This is the eyes uv diffuse texture extracted as TIF 8-bit and how it overlaps the position of the humanoid TIF diffuse texture shells.
Eyes texture:
humanoid texture:
Eyes texture on humanoid texture - layers on photoshop:
I can't re-arrange these because I'd then also need to make the UV match it precisely.
I've got two questions please:
- How can i export the textures from Maya into Mudbox so the shells don't move?
- would you recommend i use the same material for all models if I want to keep the uv map/textures as an atlas? If so, is there a way to re-assign a material to a model and re-assign the textures of the old material?
Thank you for your help,
Sergio
Eyes texture:
humanoid texture:
Sergio
4 REPLIES 4
My apologies, I was not using Photoshop's Edit-Paste Special - Paste in Place (but just paste).
However, even with this the shells are much closer to each other in the resulting merged texture with photoshop. Quite easy to see with the eye shells (in yellow) particularly bottom left.
Here's Mayas UV map and beneath pasted in place with Photoshop diffuse textures to get the atlas:
maya UV mapmaya UV mapphotoshop pasteInPlace separate mapsphotoshop pasteInPlace separate maps
Do the shells enlarge in mudbox, ever so slight? Do you have any recommendations to keep the sizes as built in Maya?
Sergio
Sergio
Christoph_Schaedl
Christoph_Schaedl
for me this looks like the edge bleeding mudbox is doing to prevent mipmapping issues...
https://linktr.ee/cg_oglu
jill.ramsay
Yes, it does look like that. You can set the bleed value in Mudbox under Windows -> Preferences -> Paint -> Edge Bleed. You can also visualize it in the UV View, if you have Render Edge Bleed turned on.
in reply to: jill.ramsay
Thanks a bunch for your thoughts and pointer to control the bleed !
