The display of the Weld lines.
Please make a functional enhancement so that after the angle of convergence more than 180
degrees, Weld lines are displayed.
Refer to the attached file:Weldlines.pdf
Reason:
The customer want to know the direction that Weld finally goes ahead through.
1 Comment
bernor_mf
The definition in Moldflow:
Where the converging flow fronts meet.:
If it is less than 135° a weld line will form.
If the angle is greater than 135° a meld line will form.
"Weld lines" result plot
The "Weld lines" result plot is there by default
After 135° weld line result disappears.
"Weld and meld lines" result plot
The "Weld and meld lines" result plot is not there by default, and you need to create New plot...
After 180° weld and meld line result disappears.
Could the "Weld and meld lines" result plot be useful for you in described case?
For 3D you also have: "Weld surface movement (3D)" result plot
Berndt
Technology Administrators
