Hello
It would be nice if we were able to rename the results in the plot properties itself.
It would be better this way when we are adding duplicate plots with different properties.
For Example, I want a "Time to ejection temp." with shaded as well as contour in the same results file.
It also helpful when we add plots. We can directly define a name for it, rather than finishing all the set up and manually renaming it later.
Regards
Sreeraj
