A transfer button from relative processing conditions results to absolute injection molding machine setup.
This mainly refers to standard thermoplastic injection molding.
I would like to see a data transfer from relative processing conditions simulation results to absolute injection molding machine setup.
When working with simulations the relative processing conditions are mostly used.
When completed, it is time to hand over some initial settings for injection molding machine setup.
At this time it would be helpful to have some realistic absolute machine setup data, from relative processing results.
1) Simulations with the relative processing conditions completed
2) Click "transfer to absolute"
3) Select a molding machine or enter molding machine data
4) Use relative results to create absolute IMM parameters
5) Set the absolute parameters in a study, and rerun, to confirm absolute settings.
6) Create a IMM setup data sheet, (yes, is a starting point, and should be aware of that)
The setup data sheet is simplified, as many unknown settings for IMM.
I am aware of uncertainties, going from theory to practice, but this would be a helpful starting point for a bunch of studies.
Thanks.
