Renaming Plots
Renaming Plots
Hello
It would be nice if we were able to rename the results in the plot properties itself.
It would be better this way when we are adding duplicate plots with different properties.
For Example, I want a "Time to ejection temp." with shaded as well as contour in the same results file.
It also helpful when we add plots. We can directly define a name for it, rather than finishing all the set up and manually renaming it later.
Regards
Sreeraj
1 Comment
Is there a set list of plots that you want to create?  You can write a script to add these for you with these properties set and the plot named to whatever you wish.  Most things can be added with the exception of the highlighted section of weld lines/weld and meld lines plots.
This way you can just click a button and add all of your plots in a fraction of a second.
