Dual domain in tutorial versus software
vgmarian
Message 1 of 9
vgmarian
I Moldflow adviser 2024, in some tutorials (fill analysis quick start tutorial and others) it says to choose 2D analysis when importing the part, however the software says the part is suited for 3D analysis. In older versions of Moldflow which I had the software said the part is suited for 2D like in the tutorial. Where is the problem?
Replies (8)
Message 2 of 9
bernor_mf
@vgmarian
Do you refer to information such as:
Moldflow Adviser Help | Quickstart Fill tutorial: Create a project | Autodesk
Generally speaking, this should have been reviewed before a release that tutorial and software agree.
Probably some tweaking in software, or unexpected defect occurred.
Believe Autodesk tech support need to review this.
@mason.myers
Mason, could you have a look at this?
Thanks.
Berndt
( If my comments are accepted, provide "Kudos" as appreciation. If your request is answered/resolved, please click the "Accept as Solution" button. Thanks.)
Message 3 of 9
mason.myers
Hello @vgmarian ,
I am not sure the last time these were updated.  As @bernor_mf  there could be minor changes in version to version.  I run most of my Adviser parts in 3D anyways.
Mason
Message 4 of 9
vgmarian
I imported a simple sheet of 1 mm thickness and 110 mm side. The software advises 3D simulation.
Message 5 of 9
mason.myers
Thank you again @vgmarian .
@raalteh Are you aware of this issue?  Please let me know if I should create a support case or JIRA ticket.
Mason
Message 6 of 9
raalteh
@mason.myers  I don't think we made intentional changes here. This could be a bug ...
Hanno van Raalte,
Product Manager - Injection Molding & Moldflow products
Message 7 of 9
bernor_mf
@raalteh @mason.myers
just wanted to follow up if you could repeat this, and found the issue?
Thanks.
Berndt
Message 8 of 9
vgmarian
Hello.
It seems the software recommends simulations on 3D on tutorial parts that before were recommended as dual domain. However, I imported a plastic cup with perfectly constant wall and the software recommended 2D. So not all parts are recommended as 3D. It seems a shift more on 3D side. However the tutorials should also be adapted.
Message 9 of 9
bernor_mf
@vgmarian
Thank you for sharing your findings. 😊
Berndt
