How to make a disc gate for a gear model
tasuke1shunta
tasuke1shunta
I want to know how to make a disc gate for a gear model in Moldflow.
bernor_mf
Hi @tasuke1shunta ,
Regarding modelling of manually trimmed gates, such as disc or diaphragm gate there is limitations in Moldflow Adviser.
There is no such modelling entities available for disc gates.
In Moldflow Insight and Moldflow Synergy (UI) you can work with mesh.
Workaround for Adviser:
I believe you need to model the disc gate together with cavity gear model in CAD, then import to Moldflow Adviser
Reference:
Disc or diaphragm gate
Manually trimmed gates
Video example: Autodesk Moldflow Fan Gate Modelling
Hope this helps.
Berndt
( If my comments are accepted, provide "Kudos" as appreciation. If your request is answered/resolved, please click the "Accept as Solution" button. Thanks.)
