Meshmixer
Welcome to Autodesk’s Meshmixer Forums. Share your knowledge, ask questions, and explore popular Meshmixer topics.
Troubles opening model
1 REPLY 1
342 Views, 1 Reply
Hi, when I try and import my model into meshmixer it opens with no texture or color. It is just an obj file with everything in it and when I open it in meshlab it has everything there. Could anyone help me with this issue?
Labels (2)
1 REPLY 1
MagWeb
The model's front faces are pointing to the inside. That should be the reason why you can't see the texture.
To flip the faces orientation (their "normals"):
Hit Ctrl+A to selectAll (Cmd+A on Mac). This switches to SELECT. In its Edit menu hit FlipNormals.
This should fix your issue, does it?
Gunter Weber
Triangle Artisan
