Meshmixer
Welcome to Autodesk’s Meshmixer Forums. Share your knowledge, ask questions, and explore popular Meshmixer topics.
'Your model is not manifold' issue
1 REPLY 1
pw2085
1575 Views, 1 Reply
Please see attached screenshot of my egg-shaped model in its original form in Meshmixer. I want to cut it in half and print each half left open (see attached desired result) so that we can put other models inside and then again close it. I cut it in half using Plane Cut (no fill), exported and opened in Cura.  There I get the message, "Your model is not manifold..." I went ahead and printed a half and this is the result.  See attached 'printed'.  I went back to Meshmixer, did Analysis-Inspector and every repair option fills the hole in the same way.  How can I accomplish this?  Thank you!
Labels (1)
1 REPLY 1
MagWeb
in reply to: pw2085
You get that non manifold warning for the cut egg is just a shell not a watertight object. Nowadays most slicers allow to print shell objects (as your print proves) but you can define the wall thickness by the number of perimeters only.
To get a watertight object with a certain wall thickness you need to hollow the object first (EDIT/Hollow) and do EDIT/PlaneCut ( with a flat infill) after that.
Gunter Weber
Triangle Artisan
