I just began to use MeshMixer and there's a thing I don't understand : when I do a plane cut, selecting "slice", sometimes the software is giving me more cutted parts than what I want : I zoomed on my model and it's like there's parts that aren't included in the cut... I don't know if I'm clear (sorry for my English)
I think the title is resuming the idea, do you have any solution ? Thanks
Plane cut should slice the whole object. Can you zip and attach the .mix and provide a screen shot.
Read here: https://help.autodesk.com/view/MSHMXR/2019/ENU/?guid=GUID-C36CDABA-05F7-44B0-9529-C33D9E435220
Do you use EDIT/PlaneCut or selection restricted cutting via SELECT/Edit/PlaneCut ?
EDIT/PlaneCut should cut all surfaces combined to one object but not the whole scene.
SELECT/Edit/PlaneCut cuts only selected regions of an object.
Gunter Weber
Triangle Artisan
