Meshmixer
Welcome to Autodesk’s Meshmixer Forums. Share your knowledge, ask questions, and explore popular Meshmixer topics.
Imported stl apears in red/pink...
10 REPLIES 10
Message 1 of 11
14182 Views, 10 Replies
Hi there
When i import a certain stl file in MM, it apears like in this picture.
The inspector did not find any erors, i can cut, transform and save it,  but when i do boolean operations, an unknown fatal error ocurred, and mm aborts.
Is something wrong with the stl and how do i repair it?
Thanks, Felix
10 REPLIES 10
Message 2 of 11
Well, becase it is a model from thingiverse, you can try yourself if it behaves in your MM like in mine, it´s the Blade from the Jet Engine Fan:
https://www.thingiverse.com/thing:1273682
Good luck...
Flix
Message 3 of 11
MagWeb
This striped rendering means you are watching the faces' back.
You simply need to flip the normals:
Go to SELECT and SelectAll. Now run Edit/FlipNormals
Gunter Weber
Triangle Artisan
Message 4 of 11
in reply to: MagWeb
Flipping the normals...
Thanks MagWeb, this was exactly what was wrong...
Flix
Message 5 of 11
in reply to: MagWeb
Hi, my model have some normals in the right way and some in the wrong way, if i select all and press flip normals, it flips all, so now i got again some in the right way and some in the wrong way. How can i flip all in the right way? i was searching the "recalculate normals" in meshmixer but i didnt find it.
Message 6 of 11
hfcandrew
Try 'generate face groups' and flips the ones you want manually.
Or select a patch that is bad then delete it then repair with Analysis>Inspector.
Or if its a really bad scan and you have thousands to do then 'make solid.
Message 7 of 11
in reply to: hfcandrew
Hi, thanks for the reply! I tried to do all the three things you’ve said, but any of them solved my problem, the convert to solid is indeed a powerful tool, in fact, the 99% of my 3d prints pass this modification before slicing. Finally i solved my problem of the flipped faces, but using other programs, and i don't know if i can write about other programs in this post, thank you so much for your reply!!!!
Message 8 of 11
MagWeb
If your object is flipped partially like this:
run EDIT/GenerateFaceGroups at the highest AngleThreshold. This creates a group for each flipped region and "positive" region:
Now go to SELECT and double click all "positive" groups:
Hit I to Invert the selection to flipped faces:
Run Edit/FlipNormals:
Gunter Weber
Triangle Artisan
Message 9 of 11
in reply to: MagWeb
hi, I have seen you on many posts regarding meshmixer. I have a stl file of a heart with the musculature in solid and the blood volume as empty. i want to obtain only the blood volume (as a solid) and 3d print that. any thoughts on how to do this with meshmixer?
Message 10 of 11
hfcandrew
Yes, always many ways and several different solutions to go about this, but since every mesh is so different, no answer can be confidently given without examining the file.
Could you start a new thread post for this and attach the file.
Message 11 of 11
Ahh yes, Here is the model . Thank you!
