Hi, I'm doing some tests using Xgen. I'm rendering with Arnold and the instances aren't rendering. Images and file attached. Thanks!
Solved by alex.bannerman. Go to Solution.
I'd actually need the Xgen files from your scene to test out on my machine. Xgen is a fickle one though, does this happen with every collection/description you make even in different scenes?
Like @Anonymous said we need the xGen files in order to see them properly in your scene.
Also, what're you using for a renderer?
Please let me know if anything changes!
All the best,
Sean Heasley
Technical Support Specialist
Autodesk Here to Help | My Screencasts | Autodesk Virtual Agent | How To Reset User Settings | Installation and Licensing Forum | Maya Certified Hardware |
All the best,
Sean Heasley
Just wanted to check in to see how things were going. Are you still having this issue?
If your issue is resolved, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
All the best,
Sean Heasley
All the best,
Sean Heasley
Hey guys, sorry again for the late reply. I went through it a few times on fresh scenes until it worked. I never really changed the process so I don't know what the solution was. The main thing was I copied the entire scene into a new scene and that did the trick. I have a few errors on startup and I use geometry from Revit, so maybe my scenes are prone to glitches.
