Maya Shading, Lighting and Rendering
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya materials topics.
Xgen Rendering Issue
4 REPLIES 4
alex.bannerman
787 Views, 4 Replies
alex.bannerman
Hi, I'm doing some tests using Xgen. I'm rendering with Arnold and the instances aren't rendering. Images and file attached. Thanks!
4 REPLIES 4
in reply to: alex.bannerman
I'd actually need the Xgen files from your scene to test out on my machine. Xgen is a fickle one though, does this happen with every collection/description you make even in different scenes?
sean.heasley
sean.heasley
Hi @alex.bannerman
Like @Anonymous said we need the xGen files in order to see them properly in your scene.
Also, what're you using for a renderer?
Please let me know if anything changes!
Hi @alex.bannerman
sean.heasley
in reply to: sean.heasley
sean.heasley
Hi @alex.bannerman
Just wanted to check in to see how things were going. Are you still having this issue?
If your issue is resolved, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Hi @alex.bannerman
alex.bannerman
Hey guys, sorry again for  the late reply. I went through it a few times on fresh scenes until it worked. I never really changed the process so I don't know what the solution was. The main thing was I copied the entire scene into a new scene and that did the trick. I have a few errors on startup and I use geometry from Revit, so maybe my scenes are prone to glitches.
