Render setting window too small only for common
Message 1 of 13
Hi, this my first time on the forum. I already search but I don't find the sollution:
I install my monthly licence this morning. When I opened the software, my render setting window was "wrong" like link in picture. I can't have it in the normal size, it the first time I have this problem.
Have you already had this problem ? How to fix it ? I can't send my renders for now... This is only for the common render, the rest is working good ( arnold renderer, system,...)
Thank's by advance for your answer !
Replies (12)
Message 2 of 13
Hello, does this happen in other scenes as well?
Message 3 of 13
Hi  emily94mc !
I don't have this problem on others scenes, only on this one even if I save as...
Message 4 of 13
Ok cool, try creating a new .ma scene, then import your old scene into it.
Hopefully that will help!
Message 5 of 13
Hi again,
unfortunately it's not working... It save only some elements randomly !
Message 6 of 13
Hi! I have met the same problem. Have you found the solution for this?
Message 7 of 13
virgil.lazar.66
Observer
Observer
Same here need a response and why it happens?
Message 8 of 13
garan119
Community Visitor
Community Visitor
My render setting window is all of a sudden like this today too on the System tab. Theres absolutely no way to resize it and make it larger and I'm so frustrated.
Message 9 of 13
brettmce
Here we are its September 18, 2023 and I am having this issue in Maya 2024! I am so frustrated, I am trying to do my job here and I can't work with my renders settings. Helloooooo!!!!! Autodesk are you there? Please help...
Message 10 of 13
cmurdo2003
I just had the same issue. I wasn't able to fix it in my scene, but I opened a new scene and referenced my 'broken' scene (File-->Reference Editor-->Create Reference). Render Settings menu is back to normal.
Message 11 of 13
movefoundry
Same, this is a problem with Maya 2024. I noticed it happens when I install Redshift. Had to revert back to 2023.
Message 12 of 13
Rebecca_Symonds
Community Visitor
Community Visitor
Hello! I was experiencing the same issue. My common tab for "Redshift" and "Arnold" were shrunk. My problem was rooted in the fact that I had locked my pixel aspect and device aspect ratio. By switching to the "Maya Software" renderer in the Render Settings, I could access the common settings and unlock the "Device aspect ratio" and the "pixel aspect ratio". Once they were unlocked, I could see the expanded view of the common tab in my renderers. I hope this solves your issue too!
 Redshift or Arnold
Message 13 of 13
animatewithabhay
This usually happens when the Render Settings UI gets corrupted or scaled incorrectly, often due to preferences or display scaling.
  1. Reset Maya preferences
    Close Maya and rename:
    Documents/maya/<version>
    to something like maya_old, then restart Maya.
  2. Check Windows display scaling
    If you’re on Windows, make sure display scaling is set to 100% (sometimes 125% or 150% breaks older Maya UIs). Restart Maya after changing it.
  3. Reset the Render Settings window
    Go to Windows → Settings/Preferences → Preferences → UI Elements and reset UI settings if available.
  4. Switch renderer and back
    Temporarily change the renderer (for example to Maya Software), close Render Settings, then switch back to Arnold.
This is a UI/layout issue, not a licensing problem, and resetting prefs or fixing DPI scaling usually resolves it completely.
