Maya Shading, Lighting and Rendering
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya materials topics.
Render setting window too small only for common
10 REPLIES 10
Message 1 of 11
2253 Views, 10 Replies
Hi, this my first time on the forum. I already search but I don't find the sollution:
I install my monthly licence this morning. When I opened the software, my render setting window was "wrong" like link in picture. I can't have it in the normal size, it the first time I have this problem.
Have you already had this problem ? How to fix it ? I can't send my renders for now... This is only for the common render, the rest is working good ( arnold renderer, system,...)
Thank's by advance for your answer !
10 REPLIES 10
Message 2 of 11
Hello, does this happen in other scenes as well?
Message 3 of 11
Hi  emily94mc !
I don't have this problem on others scenes, only on this one even if I save as...
Message 4 of 11
Ok cool, try creating a new .ma scene, then import your old scene into it.
Hopefully that will help!
Message 5 of 11
Hi again,
unfortunately it's not working... It save only some elements randomly !
Message 6 of 11
Hi! I have met the same problem. Have you found the solution for this?
Message 7 of 11
virgil.lazar.66
Same here need a response and why it happens?
Message 8 of 11
garan119
My render setting window is all of a sudden like this today too on the System tab. Theres absolutely no way to resize it and make it larger and I'm so frustrated.
Message 9 of 11
brettmce
Here we are its September 18, 2023 and I am having this issue in Maya 2024! I am so frustrated, I am trying to do my job here and I can't work with my renders settings. Helloooooo!!!!! Autodesk are you there? Please help...
Message 10 of 11
cmurdo2003
I just had the same issue. I wasn't able to fix it in my scene, but I opened a new scene and referenced my 'broken' scene (File-->Reference Editor-->Create Reference). Render Settings menu is back to normal.
Message 11 of 11
movefoundry
Same, this is a problem with Maya 2024. I noticed it happens when I install Redshift. Had to revert back to 2023.
