Maya Shading, Lighting and Rendering
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya materials topics.
Ramp opacity on ReproMesh for Mash network
2 REPLIES 2
samjproctor
212 Views, 2 Replies
I have a MASH network (set to mesh geometry) which is replicating objects along a curve.
I apply an AiStandardSurface shader to the repromesh object.
If I apply a U ramp to the geometry opacity, this appears to be controlling the opacity relative to each individual object,  instead of the opacity across all instances as a whole mesh.
Does anybody know how I can achieve this?
To be clear, imagine 10 objects distributed across the X-Axis. I want to use a ramp to control the opacity across the entire 10 objects as a whole.
Labels (4)
2 REPLIES 2
teddude75
in reply to: samjproctor
Mash a visibility node. I think that's what you are looking for. Just adjust the step strength.
samjproctor
in reply to: teddude75
I have spent hours on this! Your solution is what I was looking for and took 5 seconds! Thank you.
Technology Administrators
