Announcements
Creating water like bump map with noise
steffen.hampel
Message 1 of 13
steffen.hampel
Hello!
I am trying to create water on a plane with Vray and maya noise as a bump map. Is there any way to combine different noises in order to make it look more realistic and not just perfectly looped?
Thank you in advance,
Cheers, Steffen
Replies (12)
Message 2 of 13
sean.heasley
Hi @steffen.hampel  and welcome to the community!
You could follow along with something like this to get a basic noise:
Then there's this one, which while it isn't in English, covers a much more detailed process and gets a pretty solid render:
If one or more of these posts helped answer your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Kudos are greatly appreciated. Everyone likes a thumbs up!
Message 3 of 13
steffen.hampel
Thank you ! That definitly helped alot..
Message 4 of 13
Dave_pocket
Is it possible to scale the plane without losing the bump effect?
Message 5 of 13
damaggio
How is the bump set up?
Message 6 of 13
Dave_pocket
Like the second video tutorial, the one in arab. Almost no problem doing exactly as he says, but if i need, let's say a sea, i need a bigger plane. After scaling up the plane i tried to move some parameters in the vray water, but i ended up nowhere.
Message 7 of 13
damaggio
Boss.jpgThe Vray water is not very good, Boss system is much better for lakes and oceans.
Message 8 of 13
damaggio
Also anytime you scale something you need to freeze the transforms and recalculate the displacement amount.
Message 9 of 13
Dave_pocket
Thanks.
1. What is boss system?
Does it work with Vray?
2. I don't really know much, sorry. How do you recalculate the bump map?
Message 10 of 13
damaggio
Boss is a water system in Maya , it's part of Bifrost but it doesn't involve simulations , there are very good tutorials on YouTube, then the ocean shader  with water depth can be set up in Vray, you can use real geometry or vector displacement like the Vray water.You can add foam as well but is not very realistic.
To recalculate the bump you need to do several tests increasing the number until you get the desired amount, you can do in IPR.
The vray water can be used for small lakes and ponds but not for an ocean because it doesn't have a peak on the waves like Boss.
You can also use Vray Phoenix  system but that is a separate software.
Also when using vector displacement in Vray you need to use Explicit and enter negative numbers for min value and increase your max values according to your scale.
Message 11 of 13
damaggio
Message 12 of 13
Dave_pocket
Thanks.
I'll try that.  😉
I already found some tutorial online, and they seems good.
But, are you suggesting in using boss and then applying the ocean shader on the polygon?
Message 13 of 13
damaggio
Yes without a shader you can't render anything. You have to make the Vray ocean shader to see the results.
