I'm new to Maya. My problem is I try to use arnold lights and hypershade, when I rendering it the log shows arnold shutdown, and my arnold renderview seems to stop when half way done. I don't how to fix it.
Does anyone know what I could be doing wrong?
sorry for my english.
I'm use Maya 2018 student version/Windows 10
Solved by daunish. Go to Solution.
So, looks like your render actually finished. What makes you think it didn't?
Typically if it crashes out, you will get a better error and Arnold won't display total render time.
I'd recommend going into Arnold globals and setting your AA sample to something higher, then rerendering. Does this produce a cleaner render and longer render times? If so, you just need to set up your render scene properly, lots of youtube tutorials on how to do this. Nothing is wrong with Arnold in this case.
If this doesn't fix it then you got a more serious problem. perhaps a scene or your full log would help to figure it out.
Let me know
That log is for a swatch (shaderball) render, not for whatever was rendered in the Arnold Render View.
You must be using an older MtoA?
You can get a detailed log for the Arnold Render View: https://docs.arnoldrenderer.com/x/_grfB
Set the log verbosity to Info.
