Maya Shading, Lighting and Rendering
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya materials topics.
Ai Toon shader stylized highlights not working
14 REPLIES 14
Message 1 of 15
3797 Views, 14 Replies
I’ve been experimenting with the new Arnold toon shading, and so far I’ve been getting some fairly good results. But the stylized highlights feature I don’t seem to be able to make it work.
i tried to link multiple types of lights, tried to use the full shape name of the lights, mapped the color with a ramp, and still couldn’t make it work.
im using Maya 2018.4, which i updated hoping it could be a bug from the previous version, and reinstalled Arnold render for its latest build, 3.1.1, but still no fixes for this shader feature.
Can anyone please help me? I was really hoping to use this shader for my next project.
thanks
14 REPLIES 14
Message 2 of 15
francesco.torchia
Hi @Anonymous! Welcome to the community!
Are you using Arnold Lights? If yes, what type?
The supported light types are Distant, Point, Spot, and PhotometricMesh and Skydome lights are not supported since they can create blurred results.
Please let me know if this info helps you.
Francesco Torchia
Technical Support Specialist – M&E (3ds Max, Maya)
Message 3 of 15
in reply to: francesco.torchia
Hi, thank you for your reply.
No i`m mainly using a directional light now, but i experimented with spots,
points and area lights too that are supported by the shader.
I tried now with Arnold lights (area light) but still didn`t get any
visible result.
Regards
Message 4 of 15
francesco.torchia
Hi again @Anonymous!
Please try using an Arnold Photometric Light and tell me how it works.
Francesco Torchia
Message 5 of 15
Still, nor effect on the stylized highlights.
I plugged in and IES file in it, again, tested out linking the light to the
Stylized highlight, both shape and transform nodes, and it definitely
affects the lighting of the character, and changes the tonemap of the
shader color, but doesn`t give me no Highlights, on it.
Message 6 of 15
francesco.torchia
Hi @Anonymous!
Would you be available for a remote desktop session, so that I can see the issue directly on your machine?
If yes, please download TeamViewer and send me a private message with your ID and password.
Francesco Torchia
Message 7 of 15
Sure.
I already have TeamViewer
I hope you can find the issue
Edited by
Discussion_Admin
Message 8 of 15
francesco.torchia
Hi @Anonymous!
As mentioned during the remote session, in order to have highlights displayed, the aiToon shader needs to have Weight value of Specular higher than zero.Specular_aiToon.JPG
Francesco Torchia
Message 9 of 15
That did the trick ! 🙂
Message 10 of 15
mspeer
Hi!
Don't post private data here in the "open" forum to prevent abuse, use "Private Message" instead.
Message 11 of 15
in reply to: mspeer
hi, i replyed from my email, and din`t expect my private data would end up in the forum.
How can i remove that post ?
Message 12 of 15
mspeer
Hi!
I contacted admin to remove it.
Message 13 of 15
borbs727
in reply to: mspeer
I'm having trouble getting this to work. I've tried MMB + dragging the object from the outliner into the light parameter. I've tried typing the name of the light. I have a spec > 0 and have tried Distant (is this maya's directional light?), Point, Spot, and Photometric lights. I'm able to get an effect by light linking, but I'd like to get the shader working. Any ideas? Thanks!
Tags (2)
Message 14 of 15
Stephen.Blair
in reply to: borbs727
You're using the shape name?
// Stephen Blair
// Arnold Renderer Support
Message 15 of 15
borbs727
in reply to: Stephen.Blair
@Stephen.Blair Yep! That was it. Thanks.
Technology Administrators
