Maya Programming
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya SDK topics.
# Error: ImportError: file <maya console> line 1: No module named PySide #
5 REPLIES 5
amaterasu-qbb
8604 Views, 5 Replies
  1. Are you able to execute this code successfully?
from PySide import QtGui
class SingletonType(type):
    _instance = None
    def __call__(cls, *args, **kwargs):
        if cls._instance is None:
            cls._instance = super(SingletonType, cls).__call__(*args, **kwargs)
        return cls._instance
class MainWindow(QtGui.QMainWindow):
    __metaclass__ = SingletonType
    def __init__(self, *args, **kwargs):
        super(MainWindow, self).__init__(*args, **kwargs)
        self.setWindowTitle('Singleton Window')
        self.resize(640, 405)
when I run this code the error will show up like this.
My pycharm is already getting maya's PySide2, QtGui, QtCore and QtWidgets.
Pyside2Pyside2QtCoreQtCoreQtGuiQtGuiQtWidgetsQtWidgets
Labels (2)
5 REPLIES 5
stuzzz
in reply to: amaterasu-qbb
You may try to import PySide2 instead
amaterasu-qbb
in reply to: stuzzz
Hi! @stuzzz Thanks for the reply.
I tried to import PySide2 like this.
import PySide2
print('PySide2')
It shows PySide2 so I think I was able to import it. but when I tried that command in 1 comes error.
# Error: NameError: file <maya console> line 12: name 'QtGui' is not defined #
 so I tried. but come error again.
import PySide2
import QtGui
# Error: ImportError: file <maya console> line 2: No module named QtGui #
Have you tried the above command? Did it work?
stuzzz
I rather meant something like this:
from PySide2 import QtGui
amaterasu-qbb
in reply to: stuzzz
thank you. I did but its show the error
# Error: AttributeError: file <maya console> line 12: 'module' object has no attribute 'QMainWindow'
I tried two patterns.
import PySide2
    _instance = None
from PySide2 import QtCore, QtGui, QtWidgets
import maya.cmds as cmds
    _instance = None
I'm sorry to bother you but could you please try this code?
stuzzz
You've made a mistake here:
class MainWindow(QtWidgets.QMainWindow):
 Then there is an error concerning your metaclass design. If not sure to know what you try to achieve ...
Technology Administrators
