Maya Programming
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya SDK topics.
Python "time" flag - any way to set negative value?
2 REPLIES 2
k.nalobin
885 Views, 2 Replies
So i'm trying to delete keyframes via python script.
And the following line is working just fine:
cmds.cutKey(time=(5, 10))
However, if i'm trying to use negative time value it's doesnt work:
cmds.cutKey(time=(-5, 1))
and returns an error:
# Error: TypeError: file <maya console> line 1: Error retrieving default arguments #
is there a way to use negative time value in maya via python?
Thanks!
Labels (1)
2 REPLIES 2
mspeer
in reply to: k.nalobin
Hi!
What Maya version are you using?
Here it works.
Are you sure you had an object selected, cause if nothing is selected, then you get this error.
k.nalobin
in reply to: mspeer
well, it's seems like it was some kind of a glitch - I've just reloaded maya and everything works like a charm
thanks!
