from PySide import QtGui
class SingletonType(type):
_instance = None
def __call__(cls, *args, **kwargs):
if cls._instance is None:
cls._instance = super(SingletonType, cls).__call__(*args, **kwargs)
return cls._instance
class MainWindow(QtGui.QMainWindow):
__metaclass__ = SingletonType
def __init__(self, *args, **kwargs):
super(MainWindow, self).__init__(*args, **kwargs)
self.setWindowTitle('Singleton Window')
self.resize(640, 405)
when I run this code the error will show up like this.
# Error: ImportError: file <maya console> line 1: No module named PySide
My pycharm is already getting maya's PySide2, QtGui, QtCore and QtWidgets.
Hi! @stuzzz Thanks for the reply.
I tried to import PySide2 like this.
import PySide2
print('PySide2')
It shows PySide2 so I think I was able to import it. but when I tried that command in 1 comes error.
# Error: NameError: file <maya console> line 12: name 'QtGui' is not defined #
so I tried. but come error again.
import PySide2
import QtGui
# Error: ImportError: file <maya console> line 2: No module named QtGui #
Have you tried the above command? Did it work?
thank you. I did but its show the error
# Error: AttributeError: file <maya console> line 12: 'module' object has no attribute 'QMainWindow'
I tried two patterns.
import PySide2
from PySide2 import QtGui
_instance = None
from PySide2 import QtCore, QtGui, QtWidgets
import maya.cmds as cmds
_instance = None
I'm sorry to bother you but could you please try this code?
You've made a mistake here:
class MainWindow(QtWidgets.QMainWindow):
Then there is an error concerning your metaclass design. If not sure to know what you try to achieve ...
