Render Settings - File name prefix
Message 1 of 9
  I have been trying to get my file names to be named after the RS layer they are in.  I have tried a number ways even making layer overrides on the file names but it still just keeps putting the scn name for the file name.
The folders are naming fine but It won't match the RS layer and folder name.
thanks
Replies (8)
Message 2 of 9
sean.heasley
Hi @Anonymous
I'm a bit confused by your issue. Do you mean the names of the files of your renders or for something else?
When you get a chance, please come back with as much information/screenshots as possible and I'll be happy to assist you!
Message 3 of 9
I have attached a screenshot - but you will see that folder name is being named after the render layer but the images it is creating are not.  Render layer name "Money"  Folder name "Money"  image name "FTM_V07..."
Message 4 of 9
the images that are being rendered are not being named the same as the layer they are in....
Message 5 of 9
sean.heasley
Hi @Anonymous
I just tried this and had no issues.
Just to make sure, you have the render layer enabled and the override set to it like my screenshot below correct?render_settings.png
If this doesn't work for you, you may want to try deleting your settings/preferences.
Please let me know if this helps or if you need any more assistance!
If one or more of these posts helped answer your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Kudos are greatly appreciated. Everyone likes a thumbs up!
Message 6 of 9
sean.heasley
Hi @Anonymous
I'm just checking in again to see if you need more help with this. Did the suggestion I provided on Friday work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Message 7 of 9
Hey man - Nope still not working.
I tired that before and again now - I have used overrides and
could this be something that is messed up on my Farm?
Message 8 of 9
sean.heasley
Hi @Anonymous
Most likely. I don't have access to a render farm to test on but rendering locally I had no problems at all with the overrides for the name files.
You may want to do a simple local render test with the AOVs as well to confirm that the issue is with your farm and not your version of Maya.
Let me know if anything changes!
Message 9 of 9
cbrowneL7QTD
having this same problem. it is not a farm issue. simply changing the fil name prefix does not work. Well it changes but always reverts back to '(not set; using scene name)'
