MPxNode Derived class doesnt have attributes categories.
jonathan_ouellet
jonathan_ouellet
Hello, I created a new class which is derived from MPxNode.  Everything works fine with the compute function and the input/output.  However, when I select my node and I go in the Attributes Editor tab, my attributes are not sorted by categories.
My Node:
Locator Node:
Any clue why I don't have the Attributes drop down in my Node ("Node Behavior", Locator Attributes which should be MyNodeName Attributes) ?
Thanks !
RFlannery1
Off the top of my head, I would guess that you need to provide an Attribute Editor template file for your node.
See Maya's "scripts/AETemplates" directory for examples.  This will be located somewhere like, "C:/Program Files/Autodesk/Maya2016/scripts/AETemplates".  When you make your custom template file, I recommend not putting it in this folder.  Instead, set the MAYA_SCRIPT_PATH environment variable (if you make a .mel template file), and put your custom template in a folder on that path.  Alternately, use the MAYA_CUSTOM_TEMPLATE_PATH if you make a .xml template file.  (Honestly, I'm not sure when you are supposed to use MEL and when you are supposed to use XML.)
Edit: Forgot to mention that the template must be named after your node.  So if your new node type is "myCustomNode", then your template must be called "AEmyCustomNodeTemplate".
jonathan_ouellet
Seems like this is what I need!
But I'm not very familiar with this.  Do you know how to specify that my node will use this file ?
Thx !
Jo
jonathan_ouellet
Oh its seems to be hardcoded with the filename !  AE{nodeName}Template.mel.
Thanks again.
