Panel or Tabs visible for project only
Hi there.
I have an animation project, where I have created several QuickSets for my animation rig.
I have created a shelf tab for the QuickSets, for easy usage.
Is it possible somehow to have a shelf or a command set only visible for a certain project?
I end up with many shelfs for each character I have created in time.
Maybe it is possible to make and delete a shelf with MEL? so I can run a script, which create the shelf on project startup. (running 2017 LT upd 1)
Surely somebody, in time, must have had the need for MEL/Shelfs only available for one project or file, and not for the default file for all projects.
/thanks.
Thanks to Zhong Wu, we figured out to make a MEL script which can be run for each project.
The MEL script initialize a custom shelf and makes a delete button for the shelf, to use when the project is done.
To test the project script, make a sphere and a quick selection and insert correct names in script:
addNewShelfTab "CurrentProject";
textToShelf sphere "select -replace sphere";
textToShelf Del_Shelf "deleteShelfTab \"CurrentProject\"";
zhong_wu
Autodesk Support
Autodesk Support
Good to hear that:)
John Wu
Developer Technical Services
Autodesk Developer Network
