Help: Maya 2018 script poly projection error
Hi guys i got this script for maya:
polyProjection -type Planar -md p;
polyUVHardEdgesAutoSeams 1;
u3dLayout -res 256 -box 0 1 0 1;
what its basically does its unfold the object after selecting which edges are hard and which swift and it will unfold it on the uv editor layout , my friend use it for maya windows , but i wanna use that script on maya on the Mac osx , but the problem with the script telling me : // Error: line 3: Cannot find procedure "u3dLayout".
does this script wont work on Mac ?
sorry for my english and thanks in advance !
RFlannery1
Go into the Plug-in Manager and make sure the plugin "Unfold3D" is loaded.
alec.andersenLP8AU
Hi @Anonymous,
@RFlannery1 is correct, this is an important piece of the puzzle! Did this advice help you solve the problem? If so, make sure to mark his post as the solution! Hope you both are enjoying the holidays!
gabrielsubu11HRQSE
Community Visitor
Community Visitor
Thank you, Its really helps
subashchander_mara
Community Visitor
Community Visitor
Thank you very much. its really helped me
