Announcements
Maya api fragment graph with two maps how to assign to 2dsampler
Im writing a file texture node with two maps.
on the xml part I’m able to use both of them in the hlsl part.
but in the Cg and glsl part I need to assign them to the imagesampler.
here is the command I need to use
Maya help
But I can figure it how to use it.
In what part of the xml code I assign them.
I have map and map2 and imageSampler imageSampler2
Cheers,
Alex
cheng_xi_li
Autodesk Support
Autodesk Support
It is a known issue, the glsl code generated is incorrect. The second sampler will still be using the first sampler. I'll send you the defect id through salesforce later.
Yours,
Li
