Announcements
DeleteUI Fatal Error
I'm working on a tool that includes a language switch between English and Chinese, but when I want to reload my window or switch languages it results in a fatal crash in about 50-60% of the time. Sometimes crashing on the first reload/switch sometimes on a second or third.
I attempted to run it on an empty file on several computers, and attempted to remove the Chinese characters, but the error persisted in all cases.
Am I doing something incorrect?
global proc BSTarget_StartUI(){
    global int $selectedLanguage;
	if (`window -ex BSTarget_Window` == 1){
	        deleteUI BSTarget_Window;
	if($selectedLanguage == 0){
	        string $BSTarget_Window = `window -t "Blendshape Target Tool" -menuBar true  -s  true -vis false   -mnb true  -mxb true -widthHeight 400 200  BSTarget_Window`;
        menu -label " File ";
            menuItem -label "Reload" -c BSTarget_StartUI;
            menuItem -divider true;
            menuItem -label "Exit" -c ("deleteUI -window " + $BSTarget_Window);
        menu -label "Language - 语言";
            menuItem -label  "English" -c switchToEnglish;
            menuItem -label  "中文" -c switchToChinese;
        window -e -s 1 -w 100 BSTarget_Window;
        showWindow BSTarget_Window;
	else if ($selectedLanguage == 1){
	        string $BSTarget_Window = `window -t "混合变形目标工具" -menuBar true  -s  true -vis false   -mnb true  -mxb true -widthHeight 400 200  BSTarget_Window`;
                menu -label "文件";
            menuItem -label "重装" -c BSTarget_StartUI;
            menuItem -label "退出" -c ("deleteUI -window " + $BSTarget_Window);
global proc switchToEnglish(){
    $selectedLanguage = 0;
    BSTarget_StartUI;
global proc switchToChinese(){
    $selectedLanguage = 1;
    BSTarget_StartUI;
BSTarget_StartUI;
Solved, apparently crash was caused by the fact that I was deleting the UI from within itself.
Using evalDeferred fixed it.
