Callback to check/fix references when loading scene file?
We have a situation where many of the references in our animators' files refer to files that are local copies they have made.  So when we read their files in, those references are not found, so we have to interactively browse for the correct locations.
I'm wondering if there is a way I can get a callback before each referenced file is loaded, so I can correct the path if needed (I do have enough information to deduce the correct path).  I tried using the MSceneMessage.kBeforeReference callback, but that didn't do what I'm looking for.
Thanks!
negow
Have you tried MSceneMessage::addCheckReferenceCallback, with kBeforeLoadReference?
- https://help.autodesk.com/view/MAYAUL/2020/ENU/?guid=__cpp_ref_class_m_scene_message_html#ac6957b78a...
It claims to hand you the reference node itself, which *may* allow you to edit things like the path.
Thanks, that's very promising, I don't know how I missed that.  I'll check it out!
negow
Happes to me all the time, there are too many permutations of callbacks and flags to keep track of. 😄
